Skip to main content
Jellyfin for iOS 1.7.0
· 4 min read
Bill Thornton
Core Team, Web and iOS Lead
Download support is (finally) coming to Jellyfin for iOS!
Jellyfin for iOS version 1.7.0 delivers the long-awaited downloads feature. This update introduces global download support complete with Files app integration and sharing capabilities. Alongside this major new feature, the release brings additional technical improvements and expanded localization support. A complete list of changes, including their respective pull requests, can be found on GitHub.
Download support is here!
Direct downloads of all media types are now supported, working similarly to the Jellyfin web client and Android app. The download option will be presented in the standard UI for users with appropriate server permissions. When selected, an entry will appear in the new Downloads tab.
From the Downloads tab, users can:
  • Open downloaded media in the Files app
  • Share directly to other apps (like VLC) for viewing/playing
  • Delete downloaded content
Downloads tab with context menu showing downloaded item options
Additionally, downloaded media can be browsed directly from within the Files app by locating the Jellyfin directory under Downloads.
Transcoded downloads
Transcoded downloads have transitioned from an experimental to an alpha setting, allowing for broader community testing of this emerging capability. This feature enables transcoding of audio and video that cannot be played directly by the iOS media engine. The Jellyfin server will convert these files to a compatible format, also enabling playback of compatible videos directly within the app.
Important notes for users: Server-side support for transcoded downloads is currently very basic. You may encounter various issues, and the feature should be approached with this in mind. Currently, there are no options to control download quality, and in some cases, transcoded files may be significantly larger than the original source files. Please report any issues you encounter on GitHub.
Technical improvements
This release features several technical enhancements:
  • State Management Upgrade: State management within the app has been migrated to zustand from mobx, resolving a major blocker for upgrading to the latest Expo and React Native versions.
  • TypeScript Migration: Continued migration to TypeScript improves overall code quality and maintainability.
  • App Naming Consistency: Updates made to the app name to ensure consistent branding.
  • Expanded Localization: Added support for Afrikaans and Basque languages, thanks to our community translators.
  • Code Optimization: Removed unused resources from the app.
Supported iOS versions
This release of the Jellyfin app will be the last major update to support iOS 12. The next major release is planned to include an updated version of React Native, which will require us to increase the minimum supported iOS version to at least 15.1. Users with devices running older iOS versions will still be able to use the Jellyfin web interface, though future app updates will not be available for these devices.
Contributors
Jellyfin is completely developed by volunteers, and could not be made without their great skills and dedication. Consider donating if you appreciate their work. A big shout-out to all contributors that made this release possible:
Jellyfin Team
Other contributors
And finally a big thank you to everyone who contributed translations, reported bugs, provided feedback and participated in beta testing!
Helping out
If you have experience with React Native development and are interested in contributing, feel free to dive into the source code and open a pull request. Likewise, if you have experience with JavaScript/TypeScript and React, jellyfin-web is always looking for additional contributors. Alternatively, you can help with translating the app into your own language on our Weblate instance.
Downloads
Update your app now to check out these exciting new features! The AppStore will automatically update your Jellyfin app if you're already using it. New users can find the app on the Apple App Store.
Download on the App Store
You can also join our TestFlight and help test new versions before they're released to the public.
