Jellyfin Vue
Jellyfin Vue is an experimental, alternative browser-based web client for Jellyfin written using Vue.js.
Jellyfin Vue is not planned or targeted to replace the main Jellyfin Web client, and is not feature-complete.
Below are concise instructions to get your own instance of Jellyfin Vue up and running. If you identify with at least one of the following options:
- Want to try it quickly for the first time
- Are not sure whether you want to deploy your own instance
- Don't need to go beyond user customization to change app-wide behaviour.
- Have a working HTTPS setup.
You're probably better using our hosted instance. More info at Jellyfin Vue's repository.
Deploymentโ
Since Jellyfin Vue is just an interface for a Jellyfin server, all of these instructions assume that you already have a server up and running. Set it up now if you haven't already.
RECOMMENDED: Using Dockerโ
- In case you don't have Docker, follow the official installation guide first. Learning about Compose is also recommended.
- Docker Compose is now shipped with Docker, so you don't need to install it. It's recommended that you uninstall
the old
docker-compose. versionkey is deprecated in Docker Compose, hence not included below.
We're going to use the following docker-compose.yml as a starting point:
jellyfin_vue:
container_name: jellyfin_vue
image: ghcr.io/jellyfin/jellyfin-vue:unstable
restart: always
ports:
- 8080:80
labels:
- 'com.centurylinklabs.watchtower.enable=true'
watchtower:
container_name: watchtower
image: ghcr.io/nicholas-fedor/watchtower
- /var/run/docker.sock:/var/run/docker.sock
environment:
TZ: Europe/Madrid
WATCHTOWER_CLEANUP: 1
WATCHTOWER_INCLUDE_RESTARTING: 1
WATCHTOWER_POLL_INTERVAL: 60
WATCHTOWER_LABEL_ENABLE: 1
# Needed so watchtower doesn't restart-loop when updating itself
restart: on-failure
Getting things up and running is as easy as doing docker compose up -d with your terminal
located where the docker-compose.yml file is.
With this compose file:
- Jellyfin Vue will be accessible on
8080port of the machine that's running the containers - Watchtower (fork, the original is unmaintained)
takes care of updating the container to the latest commit available on the
repository.
This is a good idea because:
- As of now, stable releases don't exist and there have only been prereleases that don't necessarily meet a quality criteria, but major development milestones.
- Only the latest
unstableimage is supported.
After accessing the instance in your browser of choice, you'll be prompted to add a server. You can use your own server or our demo
instance, located at https://demo.jellyfin.org/stable
The server address you need to type is relative to the device you're accessing Jellyfin Vue. For instance,
if your Jellyfin Server is located at 192.168.0.10 and you have deployed Jellyfin Vue to that same server,
and your client is 192.168.0.20, the address you need to input is http://192.168.0.10, not
http://127.0.0.1 or http://localhost.
You can learn more about how the connection to your server works in Jellyfin's Vue repository privacy disclaimer
Using environment variablesโ
This is an example of how environment variables are set in the container by adding the
following keys to the jellyfin_vue definition in the above docker-compose.yml:
environment:
HISTORY_ROUTER_MODE: 1
See the complete reference of environment variables available to further customize Jellyfin Vue to your liking at Jellyfin Vue's wiki.
Using your own webserverโ
Since Jellyfin Vue is an SPA web application, you can use any web server to serve it: Apache, nginx (the one used in Jellyfin's Vue docker image), Traefik, etc...
If you already have a reverse proxy set up, do you want to do more complex stuff that it's out of the scope of this documentation like serving at a subpath, in another subdomain, etc..., you might want to have Jellyfin Vue served by your own webserver instead of the nginx instance shipped with the Docker image.
To achieve that, in the jellyfin_vue service definition of the docker-compose.yml shown above:
- Remove the
portskey. - Add the following keys, replacing
_path_with the folder where your web server expects Jellyfin Vue's assets:
network_mode: none
- _๐ฑ๐ข๐ต๐ฉ_:/dest
# This makes the container do nothing and sleep forever,
# frontend will be copied to _๐ฑ๐ข๐ต๐ฉ_ and will be served by your web server
command: /bin/sh -c 'rm -rf /dest/* && cp -r . /dest && sleep infinity'
This approach:
- Keeps the client always updated in a hassle-free way, as explained above.
- In case you use environment variables, they will still be applied.
Manuallyโ
Make sure you understand the implications before using these methods first. None of them are supported by Jellyfin Vue.
docker runโ
In case you don't want to use Docker Compose or automated updates, but still use Docker, this command is enough:
docker run -d -p 8080:80 ghcr.io/jellyfin/jellyfin-vue:unstable
From source / build outputโ
This might not be necessary if you just want to test a Pull Request. Check these instructions instead
By default, never trust any assets given by anyone outside the official channels if you can't inspect the source code first. They might compromise your system or track your activity!
Since Jellyfin Vue is a web application, using it it's a matter of setting up your own web server and pointing it to Jellyfin Vue's assets. You can get them:
- By building your own version from our source. The repository's wiki has instructions for setting up the development environment.
- By getting them from GitHub's Actions artifacts.
- Although those artifacts are built in our repository's CI/CD, some runs are sourced from Pull Requests created by external contributors that might not be good actors!
- All artifacts generated by GitHub Actions are built with provenances.
- Our official Docker image is built from GitHub Actions and all the process is transparent and can be audited.
Other documentationโ
The rest of the documentation about Jellyfin Vue can be found on it's wiki.
You can check GitHub Packages (GHCR) (recommended) or DockerHub for all the tagged Docker images.
